root\Inventory Management\log\InventoryManagement\ to store Inventory Management web application log files.web.config folder from <drive>:\IMSetup\Patch91x\ <date>_HIM_InventoryManagement_9.1.x.x.x\HIM_InventoryManagement.Config to replace the files in c:\inetpub\wwwroot\InventoryManagementc:\inetpub\wwwroot\InventoryManagement and launch WebConfig Wizard.web.config file from c:\inetpub\wwwroot\InventoryManagement to the Web.Config Wizard.Brand — select Oracle.
Server — enter the Oracle instance name.
To support multitenant use of the web application, all database users for Inventory Management must have the same password.To find the organization short name, sign in to the M Organization of Reporting and Analytics, navigate to the M Org, click System, and then click Organizations.
If left empty, you must enter the short name each time you sign in. If there are multiple organizations, separate each with a comma and you can select one when signing in.R&A Protocol — the default is http, change to https if applicable.
R&A Allowed Domains — enter a list of domains and separate each with a comma. The application rejects URLs in HTTP POST requests that do not belong to the listed domains. For example, if you enter domain1.org, domain2.com, the application does not start for an HTTP POST passing a URL from domain3.net.
R&A URL — enter the public URL for Reporting and Analytics, such as https://www.mymicros.net/.
Parent topic: Install Inventory Management
