root\Inventory Management\log\RA_Web_Service\ to store Reporting and Analytics Web Service log files.web.config file from <drive>:\IMSetup\Patch91x \<date>_RA_WebService_9.1.x.x.x\ RA_WebService.Config to replace the files in c:\inetpub\wwwroot\ RA_WebService.c:\inetpub\wwwroot\InventoryManagement and launch WebConfig Wizard.web.config file from c:\inetpub\wwwroot\RA_WebService to the Web.Config Wizard.Brand — select Oracle.
Server — enter the Oracle instance name.
Password — enter the Oracle Database user password for the schema.
Profile — enter settings.ini.
If left empty, you must enter the short name each time you sign in. If there are multiple organizations, separate each with a comma and you can select one when signing in.Parent topic: Install Reporting and Analytics Web Service
