DBMaintenance at <drive>:\IMSetup\v91Backup.FMLOGIN.INI and sql.config from the myinventory Database Maintenance installation path to <drive>:\IMSetup\v91Backup\DBMaintenance.<date>_HIM_DBMaintenance(64-bit)_9.1.0.xxx.xxxx.zip in <drive>:\IMSetup\Patch91x. Use the appropriate 32-bit or 64-bit version for your system and for the Oracle Client.setup.exe in <drive>:\IMSetup\Patch91x\<date>_HIM_DBMaintenance(64-bit)_9.1.0.xxx.xxxx. During the install, enter the Oracle Instance name.FMLOGIN.INI and sql.config files to the Database Maintenance installation pathParent topic: Patches and Updates
