After installing the 9.1 New Tech Stack or 9.1 New Tech Stack with Pentaho release, follow these steps to configure WebLogic:
- Log in to the WebLogic admin console, navigate to Environment, and then click Servers.
- Select App Server.
- Click Lock & Edit.
- Navigate to Configuration and then click General.
- Select Listen Port Enabled.
- Click Save, and then click Activate Changes.
- Navigate to Environment, click Machines, and then click <machine name> Node Manager.
- Use a fully qualified domain name for the Listen Address (for example,
reporting.mydomain.com)
- Click Save and then click Activate Changes.
- For 9.1 New Tech Stack with Pentaho installations only:
- Navigate to Environment, and then click Clusters.
- Select micros_cluster.
- Navigate to Replication.
- Select Secure Replication Enabled.
- Start the App Server.
