If you installed Enterprise Back Office without enabling SSL, follow these steps to enable SSL:
- Log in to the Oracle WebLogic console, and then upload the security certificate and enable SSL. Refer to the Oracle WebLogic help for information and instructions.
WARNING:
If you do not enable TSL 1.2, your deployment will not be compliant with security standards.
