This topic provides instructions for creating a backup and then running the wizard to remove Oracle MICROS Enterprise Back Office. Refer to the Oracle WebLogic help when uninstalling the respective software.
myMicros installation directory.myMicros folder to create a backup.installation path\myMicros\Uninstall_myMicros\ and double-click Change myMicros Installation.myMicros folder to remove all files that were not removed by the uninstallation wizard.myMicros installation directory.myMicros folder to create a backup.installation path\myMicros\Uninstall_myMicros\ and double-click Change myMicros Installation.myMicros folder to remove all files that were not removed by the uninstallation wizard.Parent topic: Uninstallation
