PreviousNextJavaScript must be enabled to correctly display this content
Routing-based RN Configuration
This section shows you how to specify that a set of local policy attributes should use an RN for lookup. You can also set this value to CIC, or to any value you require.
You can set the lookup key to an RN in the local policy attributes’
next-hop parameter.
To set the lookup key to RN:
In Superuser mode, type
configure terminal and press Enter.
