System Identification
You must specify identification parameters for this Oracle® Enterprise Session Border Controller.
Set the following parameters to configure the system identification:
- hostname—Set the primary hostname used to identify the system. This parameter is used by the software for informational purposes.
- description—Enter a textual description of the system. This parameter is used for informational purposes.
- location—Set a location description field for the system. This parameter is used for informational purposes. For example, you might include the site name and address of the location where the system chassis is located.
- default-gateway—Set the default gateway for this Oracle® Enterprise Session Border Controller. This is the egress gateway for traffic without an explicit destination. The application of the Oracle® Enterprise Session Border Controller determines the configuration of this parameter.
