ACLI Instructions and Examples
To configure general system information:
In Superuser mode, type configure terminal and press Enter.
ORACLE# configure terminal
Type system and press Enter to access the system-level configuration elements.
ORACLE(configure)# system
Type system-config and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(system)# system-config ORACLE(system-config)#
The following is an example what a general system information configuration might look like. Parameters not described in this section are omitted below.
ORACLE(system-config)# show system-config hostname test1 description Example SD location Row 3, Rack 4, Slot 451 default-gateway 10.0.2.1 telnet-timeout 1000 console-timeout 1000 last-modified-date 2004-12-08 20:15:43
When showing a single-instance configuration element such as system-config, you must first use the select command to select the configuration element prior to viewing.
