Searching Globally
When you use the find command without directing your search to the editing configuration, running configuration, or ACLI command (parameter) menu, the system searches and returns data for all three. The display identifies in which of the three areas results are found.
Note that:
- The system does not display editing configuration if it is the same as running configuration.
- Command results are not displayed if the Attribute context is present.
ORACLE# find * Command menu --------------------------- (root) capture start realm <main-filter> * (root) capture start session-agent <main-filter> * (root) capture start global * (root) show directory * Editing configuration -------------------- session-router -> local-policy [*; *; 172.16.11.2] from-address * source-realm * session-router -> local-policy [*; *; 192.168.11.2] from-address * source-realm * session-router -> local-policy [*; *; 123] from-address * source-realm * session-router -> local-policy [net172; *; *] from-address * to-address * session-router -> local-policy [net192; *; *] from-address * to-address * session-router -> sip-config registrar-domain * registrar-host * session-router -> sip-monitoring monitoring-filters *, Running configuration ------------------ session-router -> local-policy [*; *; 172.16.11.2] from-address * source-realm * session-router -> local-policy [*; *; 192.168.11.2] from-address * source-realm * session-router -> local-policy [*; *; 123] from-address * source-realm * session-router -> local-policy [net172; *; *] from-address * to-address * session-router -> local-policy [net192; *; *] from-address * to-address * session-router -> sip-config registrar-domain * registrar-host * session-router -> sip-monitoring monitoring-filters *, Found 30 instances ORACLE#
