Searching the ACLI Menu
When you use the find command option, the systems displays all menu items matching the string you specify (case-sensitive, sub-string match). This search includes all root-level and configuration-level parameters, and displays the full path to each value it displays.
ORACLE# find command srtp (root) show sa stats <srtp> (configure) media-manager realm-config srtp-msm-passthrough (configure) media-manager vbg-config srtp (configure) security media-security sdes-profile srtp-auth (configure) security media-security sdes-profile srtp-encrypt (configure) security security-config srtp-msm-password (configure) security security-config srtp-msm-attr-name Found 7 instances ORACLE#
