SIP Port Mapping Configuration for TCP TLS
You enable TCP/TLS port mapping in a per-realm basis using the SIP interface configuration; setting the tcp-port-mapping value in the options parameter enables the feature. Enabling this parameter turns on the port mapping feature for UDP as well.
By default, the Oracle® Enterprise Session Border Controller includes the Path header in Register requests it sends from that SIP interface. If you do not this header to be included, however, you can set the value as tcp-port-mapping=nopath.
To enable TCP/TLS port mapping for a SIP interface:
