In-Realm Codec Manipulations
To enable in-realm codec manipulations:
In Superuser mode, type configure terminal and press Enter.
ORACLE# configure terminal
Type media-manager and press Enter.
ORACLE(configure)# media-manager
Type realm-config and press Enter.
ORACLE(media-manager)# realm-config
If you are adding support for this feature to a pre-existing realm, then you must select (using the ACLI select command) the realm that you want to edit.
codec-manip-in-realm—Enter the name of the codec policy that you want to apply to this realm. The default value is disabled. The valid values are:
enabled | disabled
- Save and activate your configuration.
