PreviousNextJavaScript must be enabled to correctly display this content
Applying a Codec Policy to a Session Agent
Note that codec policies that are defined for session agents always take precedence over those that are defined for realms.
To apply a codec policy to a realm:
In Superuser mode, type configure terminal and press Enter.
ORACLE# configure terminal
Type session-router and press Enter.
ORACLE(configure)# session-router
Type session-agent and press Enter.
ORACLE(session-router)# session-agent
If you are adding support for this feature to a pre-existing session agent, then you must select (using the ACLI select command) the realm that you want to edit.
codec-policy—Enter the name of the codec policy that you want to apply to this realm. By default, this parameter is empty.
