Signaling Checkpointing Configuration
To configure SIP signaling checkpointing across an HA node in the ACLI:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the system-level configuration elements.
ORACLE(configure)# session-router
Type
session-router and press Enter.
ORACLE(session-router)# sip-config
From here, you can configure SIP parameters for HA nodes. To view all SIP configuration parameters, enter a ? at the system prompt.
When configuring SIP for HA, you only need to set the parameters addressed in this procedure.
red-sip-port—Enter the port on which SIP signaling checkpointing messages are sent and received. The default value is
1988. A value of
0 disables the SIP signaling checkpointing. The valid range is:
Minimum—0, 1024
Maximum—65535
red-max-trans—Enter the maximum size of the transaction list, or how many SIP transactions you want to store in memory at one time. Oldest transactions will be discarded first in the event that the limit is reached. The default value is
10000. The valid range is:
Minimum—0
Maximum—999999999
red-sync-start-time—Enter the number of milliseconds before the
Oracle® Enterprise Session Border Controller will try to synchronize its signaling state checkpointing.
If the active Oracle® Enterprise Session Border Controller is still adequately healthy, this timer will simply reset itself. If for any reason the active Oracle® Enterprise Session Border Controller has become the standby, it will start to checkpoint with the newly active system when this timer expires.
We recommend that you leave this parameter set to its default, 5000. The valid range is:
Minimum—0
Maximum—999999999
red-sync-comp-time—Enter the number of milliseconds representing how frequently the standby
Oracle® Enterprise Session Border Controller checkpointing with the active
Oracle® Enterprise Session Border Controller to obtain the latest SIP signaling information. The first interval occurs after initial synchronizations of the systems.
We recommend that you leave this parameter set to its default, 1000. The valid range is:
Minimum—0
Maximum—999999999
