SIP Signaling Checkpointing
In the SIP configuration, you can set parameters that enable SIP signaling checkpointing across an HA node.
When configured, these parameters will appear in the ACLI as they do in example below.
This example shows the default values being used, and we recommend that you do not change these values from their defaults.red-sip-port 1988 red-max-trans 10000 red-sync-start-time 5000 red-sync-comp-time 1000
