Applying an Enforcement Profile to a Realm For the Oracle® Enterprise Session Border Controller to use the limits you have set up, you need to apply them to a realm. To apply an enforcement profile to a realm: In Superuser mode, type configure terminal and press Enter. ORACLE# configure terminal ORACLE(configure)# Type media-manager and press Enter. ORACLE(configure)# media-manager ORACLE(media-manager)# Type realm-config and press Enter. If you are adding this feature to a pre-existing realm configuration, you will need to select and edit your realm. ORACLE(media-manager)# realm-config ORACLE(realm-config)# enforcement-profile—Enter the name of the enforcement profile you want to apply to this realm. This value corresponds to the name parameter in the enforcement profile configuration. This parameter has no default value. Save and activate your configuration.
