Setting Up Subscribe Dialog Limits
Setting up subscribe dialog limits means setting up an enforcement profile. For the sole purpose of setting up the subscription event limits, you only need to configure the name parameters and then as many subscribe-event configurations as you require. The enforcement profile has other uses, such as SIP SDP address correlation, so only configure the parameters you need.
To configure subscribe dialog limits:
