Adding an ACL for the Management Interface
The new subconfiguration system-access-list is now part of the system configuration, and its model is similar to host routes. For each entry, you must define an IP destination address and mask; you can specify either the individual host or a unique subnet.
If you do not configure this list, then there will be no ACL/DoS protection for the Oracle® Enterprise Session Border Controller’s management interface.
You access the system-access-list via system path, where you set an IP address and netmask. You can configure multiple system ACLs using this configuration.
To add an ACL for the management interface:
