Static Flow Policing
Static flow policing is configured with one parameter found in the static-flow configuration element. To configure CBR, you have to set the average-rate-limit parameter to a non-zero value. Setting the parameter listed below to 0 disables static flow policing, effectively letting the flow pass through the Oracle® Enterprise Session Border Controller unrestricted.
In a CBR configuration, the average-rate-limit parameter determines the maximum bandwidth available to the flow.
- average-rate-limit—Establishes the maximum speed for a static flow in bytes per second.
Static flow policing is not necessarily tied to any type of media traffic, it can affect flows of any traffic type.
