PreviousNextJavaScript must be enabled to correctly display this content
Media Policing Configuration for RTP Flows
You can configure media policing in the
media-profile configuration element using the ACLI. In the following example, you will configure media policing for the G723 media profile.
To configure media policing for RTP flows:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the
session-router path.
ORACLE(configure)# session-router
Type
media-profile
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# media-profile
Select an existing media profile to which you will add policing constraints.
From this point, you can configure media policing parameters. To view all
media-profile parameters, enter a
? at the system prompt
average-rate-limit—Enter the maximum rate in bytes per second for any flows that this
media-profile
polices. The default value is zero (0), disabling media policing. The valid range is:
Minimum—0
Maximum—125000000
Average rate limit values for common codecs:
PCMU—80000 Bps
G729—26000 Bps
The following example shows a
media-profile configuration element configured for media policing.
media-profile
name G723
media-type audio
payload-type 4
transport RTP/AVP
req-bandwidth 16
frames-per-packet 0
parameters
average-rate-limit 15000
