Media Policing Configuration for RTCP Flows You can configure media policing for RTCP flows by using the ACLI. To configure media policing for RTCP flows: In Superuser mode, type configure terminal and press Enter. ORACLE# configure terminal Type media-manager and press Enter to access the media-manager path. ORACLE(configure)# media-manager Type media-manager and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters. ORACLE(media-manager)# media-manager ORACLE(media-manager-config)# rtcp-rate-limit—Enter the RTCP policing constraint in bytes per second. The default value is zero (0). The valid range is: Minimum—0 Maximum—125000000
