Media Policing Configuration for Static Flows
You can configure media policing for static flows using the ACLI.
To configure media policing for static flows:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager and press Enter to access the
media-manager path.
ORACLE(configure)# media-manager
Type
static-flow
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(media-manager)# static-flow ORACLE(static-flow)#
Select an existing static flow to which you will add policing constraints.
ORACLE(static-flow)# select <in-dest-ip>: 1: dest 0.0.0.0; src 192.168.2.1/24; static-flow-in-realm; UDP selection:1
From this point, you can configure media policing parameters for static flows. To view all static-flow parameters, enter a ? at the system prompt
average-rate-limit—Enter the maximum rate in bytes per second for any flows that this
static-flow
polices. The default value is zero (0). The valid range is:
Minimum—0
Maximum—125000000
The following example shows a static-flow configuration element configured for media policing.
static-flow in-realm-id static-flow-in-realm in-source 192.168.2.1/24 in-destination 0.0.0.0 out-realm-id static-flow-out-realm out-source 192.168.128.1/24 out-destination 0.0.0.0 protocol UDP average-rate-limit 15000
