PreviousNextJavaScript must be enabled to correctly display this content
Deleting a License from a Standalone System
You can delete a license from your
Oracle® Enterprise Session Border Controller, including licenses that have not expired. If you want to delete a license that has not expired, you need to confirm the deletion.
To delete a license from the
Oracle® Enterprise Session Border Controller:
In Superuser mode, type configure terminal and press Enter.
ORACLE# configure terminalORACLE(configure)#
Type
system and press Enter.
ORACLE(configure)# systemORACLE(system)#
Type license and press Enter.
ORACLE(system)# licenseORACLE(license)#
Type the
no command and press Enter. A list of possible licenses to delete appears.
ORACLE(license)# no
feature:
1: High Availability
2: Accounting
3: SIP
4: H323
5: 250 sessions, ACP
6: QOS
selection:
ORACLE(license)#
Type the number corresponding to the license you want to delete and press Enter.
selection:6
If the license has not expired, you will be asked to confirm the deletion.
When you show the licenses, the one you deleted should no longer appear on the list.
To clear the license from the system, type the
activate-config command and press Enter. The
Oracle® Enterprise Session Border Controller then disables any of the processes that support associated features.
