Add a License Key
Once you have obtained a license key, you can add it to your Oracle® Enterprise Session Border Controller and activate it.
Access the
license configuration element.
ORACLE# configure terminal ORACLE(configure)# system ORACLE(system)# license ORACLE(license)#
Using the
add command and the license key you received from
Oracle, add the license to your
Oracle® Enterprise Session Border Controller.
ORACLE(license)# add sl25o39pvtqhas4v2r2jc1oaen9e01o21b1dmh3Note:
Do note type done after you add the license. If you do, the system will return an error. -
You can check that the license has been added by using the ACLI
show command within the license configuration.
ORACLE(license)# show License #1: 16000 sessions, SIP, LI, Transcode Codec AMR (25 AMR transcoding sessions), Transcode Codec EVRC (25 EVRC transcoding sessions), Transcode Codec Opus (25 OPUS transcoding sessions), Transcode Codec SILK (25 SILK transcoding sessions) expires at 06:28:15 Feb 07 2106 installed at 17:03:53 May 04 2017 ORACLE(license)#
Do not type done before exiting the license configuration element. -
Type
exit until you return to the top-level superuser prompt.
ORACLE(license)# exit ORACLE(system)# exit ORACLE(configure)# exit ORACLE#
Perform a save- and activate- on the configuration.
ORACLE# save-config checking configuration -------------------------------------------------------------------------------- Results of config verification: 0 configuration error -------------------------------------------------------------------------------- Save-Config received, processing. waiting for request to finish Request to 'SAVE-CONFIG' has Finished, Save complete Currently active and saved configurations do not match! To sync & activate, run 'activate-config' or 'reboot activate'. ORACLE# activate-config Activate-Config received, processing. waiting for request to finish Setting phy on Slot=0, Port=0, MAC=00:08:25:22:81:B0, VMAC=00:08:25:22:81:B0 Setting phy on Slot=0, Port=1, MAC=00:08:25:22:81:B1, VMAC=00:08:25:22:81:B1 Request to 'ACTIVATE-CONFIG' has Finished, Activate Complete
