Enabling Disabling SIP Monitoring & Tracing
You can enable or disable the Oracle® Enterprise Session Border Controller (E-SBC) to perform SIP monitoring using the state parameter at the path in the ACLI.
Use the following procedure to enable/disable SIP monitoring on the E-SBC.
You must enable the sip-monitoring object for monitoring and filtering to occur on the E-SBC. With sip-monitoring enabled, you can configure a filter(s) on a global basis, as well as for a session agent and/or a realm. You can also initiate dynamic filter commands.To enable/disable sip-monitoring:
