Configuring QoS
This section explains how to configure QoS. To generate QoS metrics, you need to enable QoS for the realm of the originating caller. The ingress realm determines whether QoS is turned on for a specific flow.
If you run with QoS turned on one side only and disabled on the other you lose the ability to measure latency through the use of RTCP timestamps.
