QoS Configuration
To enable QoS:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager and press Enter.
ORACLE(configure)# media-manager
Type
realm-config
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(media-manager)# realm-config ORACLE(realm-config)#
- qos-enable—Enable this parameter. The default value is disabled.
