About Wildcarding
You can wildcard both portions (name and subname) of this value:
- When you wildcard the name portion of the value, you can provide a specific subname that the Oracle® Enterprise Session Border Controller uses to find matching media profiles.
- When you wildcard the subname portion of the value, you can provide a specific name that the Oracle® Enterprise Session Border Controller uses to find matching media profiles.
You can also enter the name value on its own, or wildcard the entire value. Leaving the subname value empty is also significant in that it allows the realm to use all media profile that have no specified subname. However, you cannot leave the name portion of the value unspecified (as all media profiles are required to have names).
Consider the examples in the following table:
| Syntax | Example Value | Description |
| <name> | PCMU | Matches any and all media profiles with the name value configured as PCMU. This entry has the same meaning as a value with this syntax: <name>::*. |
| <name>:: | PCMU:: | Matches a media profile with the name with the name value configured as PCMU with an empty subname parameter. |
| <name>::<subname> | PCMU::64k | Matches a media profiles with the name with the name value configured as PCMU with the subname parameter set to 64k. |
| * | * | Matches anything, but does not have to be a defined media profile. |
| *::* | *::* | Matches any and all media profiles, but requires the presence of media profile configurations. |
| *::<subname> | *::64k | Matches all media profiles with this subname. You might have a group of media profiles with different names, but the same subname value. |
| *:: | *:: | Matches any media profiles with an empty subname parameter. |
| :: | :: | Invalid |
| ::* | ::* | Invalid |
The Oracle® Enterprise Session Border Controller performs matching for wildcarded match-media-profiles values last. Specific entries are applies first and take precedence. When the Oracle® Enterprise Session Border Controller must decide between media profiles matches, it selects the first match.
To use media profiles for a realm:
