Media Profile Configuration
This section shows you how to configure multiple media profiles per realm, and it explains how to use wildcarding.
To reference a media profile in this list, you need to enter its name and subname values in the following format <name>::<subname>. Releases C6.1.0 and later accept the subname so you can configure multiple media profile for the same codec; the codec name customarily serves and the name value for a media profile configuration.
