H.323 BIS Specific Configuration
To enable the H.323 BIS feature for a specific H.323 interface:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router
and press Enter to access the signaling-related configurations.
ORACLE(configure)# session-router
Type
h323 and press Enter.
ORACLE(session-router)# h323
Type
h323-stacks and press Enter.
ORACLE(h323)# h323-stacks ORACLE(h323-stacks)#
Select the H.323 stack to which you want to add H.323 BIS support.
ORACLE(h323-stacks)# select <name>:
For a list of configured H.323 interfaces (stacks), press Enter at the <name>: prompt. Then enter the number corresponding to the interface where you want to apply this feature.
Type
options +bearerIndSetup
and press Enter.
ORACLE(h323-stacks)# options +bearerIndSetup
If you type options bearerIndSetup without the plus (+) sign, you will remove any previously configured options. In order to append the new option to the options list, you must prepend the new option with a plus sign as shown in the example above.
