H.323 BIS Global Configuration
This section explains how to add H.323 BIS support to your global H.323 configuration and to specific H.323 interfaces (stacks).
If you set this option on an H.323 interface (stack), you must set it on the interface (stack) that receives the Setup message with BIS in the Bearer Capability IE.
To enable the H.323 BIS feature globally:
