Enable Basic Mode and or Expert Mode
Enter
1
to enable Basic Mode and Expert Mode or
2
to enable Expert Mode only. Press Enter.
Enter choice [1 - basic] :1Note:
If you enable both Basic and Expert Modes (selection 1), after logging into the Web GUI, the Basic Mode screen displays by default. You can switch to Expert Mode if you do not make any changes in Basic Mode, using the Switch to Expert button. If you enable Expert Mode only (selection 2), no button displays to switch to Basic Mode.The following displays.
========================================================= HIGH AVAILABILITY This SBC may be a standalone or part of a highly available redundant pair. SBC mode 1 - standalone 2 - high availability Enter choice [1 - standalone] : ========================================================= -
Enter
1 for a standalone server or enter
2 to configure an HA device. Press Enter and go to Step 4 in
Setting Up High Availability (HA) Mode to complete the installation.
It is highly recommended that you configure high availability (HA) using this Installation Wizard.Enter choice [1 - standalone] :1The following displays.
========================================================= SBC SETTINGS Unique target name of this SBC [<SBC name>] : =========================================================
Enter
a unique target name for the NN-ESD (or keep the default in [ ]),
and press Enter.
========================================================= IP address on management interface [<SBC IP address>] : =========================================================
Enter
the IP address to be used for accessing the Web GUI (or keep the default in [ ]),
and press Enter.
IP address on management interface [<SBC IP Address>] : 164.30.85.51
========================================================= Subnet mask [<subnet mask>] : =========================================================
Enter the subnet mask of the
Oracle® Enterprise Session Border Controller (or keep the default in [ ]), and press Enter.
Subnet mask [<subnet mask>] : 255.255.0.0
========================================================= Gateway IP address [<Gateway IP address>] : =========================================================
Enter the gateway IP address
and press Enter.
Gateway IP address [<Gateway IP address>] :164.30.0.1
========================================================= -- Summary view ------------------------------------- GUI ACCESS 1: Enable Web GUI (yes/no) : yes WEB GUI MODE 2 : Web GUI Mode : basic HIGH AVAILABILITY 3 : SBC mode : standalone 4 : SBC role : N/A SBC SETTINGS 7 : Unique target name of this SBC : lise_primary 8 : IP address on management interface : 164.30.85.51 9 : Subnet mask : 255.255.0.0 10: Gateway IP address : 164.30.0.1 AUTOMATIC CONFIGURATION 11: Acquire config from the Primary (yes/no) : N/A PEER CONFIGURATION 13: Peer target name : N/A Enter 1 - 16 to modify, 'd' to display summary, 's' to save, 'q' to exit. [s]: =========================================================
Only the fields that were configured display in the summary view. -
Enter
s to save the configuration. Or select an item number from the summary view to modify the value for that item. Or enter
q to exit the installation wizard without saving the setup.
Enter 1 - 16 to modify, 'd' to display summary, 's' to save, 'q' to exit. [s] :sThe following displays.
========================================================= Saving changes and quitting wizard. Are you sure? [y/n]? : =========================================================
Enter
y to verify you want to save the configuration and press Enter.
Saving changes and quitting wizard. Are you sure? [y/n]? :yThe following displays.
========================================================= Running configuration is backed up as 'bkup_setup_wizard_Apr_18_13_04_57_970.gz' ****************************************************** Deleting configuration Erase-Cache received, processing. waiting 1200 for request to finish Request to 'ERASE-CACHE' has Finished, Erase-Cache: Completed Request to 'RESTORE-CONFIG' has Finished, Restore Backup Completed Successfully checking configuration Save-Config received, processing. waiting for request to finish Request to 'SAVE-CONFIG' has Finished, Save complete Currently active and saved configurations do not match! To sync & activate, run 'activate-config' or 'reboot activate'. ------------------------------------------------------ Verification successful! No errors nor warnings in the configuration Activate-Config received, processing. waiting for request to finish Request to 'ACTIVATE-CONFIG' has Finished, Activate Complete -- Saved configuration. ---------------------------- GUI ACCESS 1: Enable Web GUI (yes/no) : yes WEB GUI MODE 2 : Web GUI Mode : basic HIGH AVAILABILITY 3 : SBC mode : standalone 4 : SBC role : N/A SBC SETTINGS 7 : Unique target name of this SBC : jane_primary 8 : IP address on management interface : 164.30.85.51 9 : Subnet mask : 255.255.0.0 10: Gateway IP address : 164.30.0.1 AUTOMATIC CONFIGURATION 11: Acquire config from the Primary (yes/no) : N/A PEER CONFIGURATION 13: Peer target name : N/A You may access the GUI via http://164.30.85.51:80/ after reboot. =========================================================
You have completed the Installation Wizard.
For more information about using the Web GUI, see the Net-Net Enterprise Session Director Web GUI User Guide.
You can configure the Web Server for using Transport Layer Security (TLS). You can also manage the Web Server using specific commands. For more information about configuring TLS on the Web Server, and for information about Web Server management commands, see Chapter 22, Web Server TLS Configuration and Management Commands.
