ACLI Command Support
This section describes common ACLI commands supported only on the VM Edition. Because the VM Edition is a software-only product, you may find that ACLI commands relating to hardware components are not supported or differ in syntax and output.
For more information about using the ACLI Show commands in this section, see the Net-Net® 4000 Maintenance and Troubleshooting Guide.
