Packet Capture Initiation
From the command line, you can initiate a live packet capture session to view packet traffic on your network. For example, you might want to confirm the network configuration or to perform troubleshooting.
During a packet capture session, the system creates a set of .pcap files in the /opt/traces directory. If the /opt/traces directory contains files when you run the packet-trace command, the system prompts you to either remove or keep the existing files before running the command. The following table describes the system behavior for both options.
| Option | Result | Packet Trace Command Behavior |
| Yes | Removes all existing files. | The system captures up to 25 new .pcap files. During the session, the system rotates the files in the /opt/traces directory by size. For example, the system keeps the last 25 files and rotates them when they reach 100 MB |
| No | Keeps all existing files. |
Use the
packet-trace [local | remote] [start | stop] [<network-interface>] command to initiate a packet capture session.
