Packet Trace PCAP
The VM Edition packet tracing support differs from the other Oracle® Enterprise Session Border Controller (E-SBC) platforms. When enabled, the system captures packets that meet specific criteria. The system logs the packets into a file in the /opt/traces directory in a PCAP-formatted format, and displays the information to the ACLI session from which the capture was executed.
You can enable or disable packet capture on the E-SBC. The default filter uses port 5060 on the specified interface to capture both ingress and egress ICMP traffic.
