Denial of Service (DoS) Configuration Defaults
The following example shows default DoS values in the media-manager configuration.
media-manager max-signaling-bandwidth 332000 max-untrusted-signaling 100 min-untrusted-signaling 30 app-signaling-bandwidth 0 tolerance-window 30 arp-msg-bandwidth 32000
Based on the default values, the system calculates the trusted, untrusted, ARP, and events packets per second.
Use the show sw-datapath DOS settings command to display these values.
# show sw-datapath DOS settings Queue Size PPS ARP reply 375 250 ARP request 375 250 Trusted 210 142 Untrusted 300 200 Event 8192 9000
