Tailoring Show Running for Templates
You can use the following commands to display information for a configuration made from a template. The only templated configuration that you can view is related to SIP Trunk Xpress (SIPTX).
- show run service—Displays all services you created using a template.
- show run prfile—Displays all profiles you created using a template.
- show run static-vars—Displays all status variables you created using a template.
