Showing Running for Templated Configuration
The output from the show run command looks different for configuration generated using templates. The only templated configuration you can view is related to SIP Trunk Xpress (SIPTX).
The following example shows what the output for show run looks like with configuration produced from a template. Only profiles, services, and statically-produced configuration are displayed.
ORACLE# show running-config
profile
profile-name defaultAccounting
template-name Accounting
profile-state enabled
acctProto
acctState
acctGenStart
acctGenInterim
acctAddress
service
service-name accounting1
service-state enabled
acctProto RADIUS
acctState enabled
acctGenStart INVITE
acctGenInterim OK
acctAddress 172.16.11.2
The following example shows what the output for show run generated looks like when a configuration is generated by a template. The display shows whether the configuration was generated by a profile, service, or template.
ORACLE# show running-config generated
account-config
hostname localhost
port 1813
strategy Hunt
protocol RADIUS
state enabled
max-msg-delay 60
max-wait-failover 100
trans-at-close disabled
generate-start Invite
generate-interim Reinvite-Response
OK
intermediate-period 0
file-output disabled
file-path /ramdrv/logs/
max-file-size 1000000
max-files 5
file-compression disabled
file-rotate-time 0
options
file-delete-alarm disabled
ftp-push disabled
ftp-address
ftp-port 21
ftp-user
ftp-password
ftp-remote-path
cdr-output-redundancy enabled
interim-stats-id-types
account-servers
hostname 172.16.11.2
port 1813
state enabled
min-round-trip 250
max-inactivity 60
restart-delay 30
bundle-vsa enabled
secret
NAS-ID
priority 0
origin-realm
domain-name-suffix
prevent-duplicate-attrs disabled
vsa-id-range
cdr-output-inclusive disabled
ftp-strategy Hunt
ftp-max-wait-failover 120
generated-by-template Accounting
generated-by-profile defaultAccounting
generated-by-service accounting1
