Example 15 Change and Remove Lines from SDP
In this sample of changing and removing lines from the SDP, the goal is to convert the G.729 codec to G.729a. The SIP manipulation would be configured like the following:
sip-manipulation
name std2prop-codec-name
description rule to translate standard to proprietary codec name
header-rule
name CTypeManp
header-name Content-Type
action manipulate
comparison-type case-sensitive
match-value
msg-type any
new-value
methods
element-rule
name g729-annexb-no-std2prop
parameter-name application/sdp
type mime
action find-replace-all
match-val-type any
match-value a=rtpmap:[0-9]{1,3}(G729/8000/1\r\na=fmtp:[0-9]{1,3} annexb=no)[[:1:]]
new-value G729a/8000/1
The result of manipulating the original SIP INVITE (shown above) with the configured SIP manipulation is:
INVITE sip:service@192.168.1.61:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.1.60:5060;branch=z9hG4bK-1-0 From: sipp <sip:sipp@192.168.1.60:5060>;tag=1 To: sut <sip:service@192.168.1.61:5060> Call-ID: 1-15554@192.168.1.60 CSeq: 1 INVITE Contact: <sip:sipp@192.168.1.60:5060;user=phone> Max-Forwards: 70 Content-Type: multipart/mixed;boundary=boundary Content-Length: 466 --boundary Content-Type: application/sdp v=0 o=user1 53655765 2353687637 IN IP4 192.168.1.60 s=- c=IN IP4 192.168.1.60 t=0 0 m=audio 12345 RTP/AVP 8 a=rtpmap:18 G729a/8000/1 a=sendrecv a=maxptime:200 --boundary Content-Type: application/sdp v=0 o=user1 53655765 2353687637 IN IP4 192.168.1.60 s=- c=IN IP4 192.168.1.60 t=0 0 m=video 12345 RTP/AVP 34 a=rtpmap:34 H263a/90000 --boundary-
