Example 14 Back Reference Syntax
In this sample of back-reference syntax use, the goal is to change the To user. The SIP manipulation would be configured like the following:
sip-manipulation
name changeToUser
description change user in the To header
header-rule
name ChangeHeader
header-name To
action manipulate
comparison-type case-sensitive
match-value
msg-type request
new-value
methods INVITE
element-rule
name replaceValue
parameter-name
type header-value
action replace
match-val-type any
comparison-type pattern-rule
match-value (.+)(service)(.+)
new-value $1+Bob+$3
The result of manipulating the original SIP INVITE (shown above) with the configured SIP manipulation is:
INVITE sip:service@192.168.1.61:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.1.60:5060;branch=z9hG4bK-1-0 From: sipp <sip:sipp@192.168.1.60:5060>;tag=1 To: sut <sip:Bob@192.168.1.61:5060> Call-ID: 1-15554@192.168.1.60 CSeq: 1 INVITE Contact: <sip:sipp@192.168.1.60:5060;user=phone> Max-Forwards: 70 Content-Type: multipart/mixed;boundary=boundary Content-Length: 466 … … …
