Configuring a Realm
To configure a realm:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager
and press Enter to access the system-level configuration elements.
ORACLE(configure)# media-manager
Type
realm-config
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(media-manager)# realm-config ORACLE(realm-config)#
- If configuring an existing realm, enter the select command to select the realm.
early-media-allow—Enter the early media suppression rule for the realm. The valid values are:
both—Early media is allowed in both directions
reverse—Early media received by Oracle® Enterprise Session Border Controller in the reverse direction is allowed
none—Early media is blocked
additional-prefixes—Enter a single or a comma-delimited list of IP address prefixes to use in addition to the value of the
addr-prefix
parameter.
<IPv4> [/<number of bits>]
<IPv4> is a valid IPv4 address and <number of bits> is the number of bits to use to match an IP address with the address prefix. Not specifying <number of bits> implies that all 32 bits are used for matching.
Enclose the list between quotes if there is any space between a comma and the next address prefix.
You can add and remove address prefixes to and from the list:
add-additional-prefixes adds one or more additional prefixes
add-additional-prefixes 192.168.201.69
remove-additional-prefixes removes one or more additional prefixes
remove-additional-prefixes 192.168.201.69
If using multiple address prefixes, enter a comma-delimited list.
Save and activate your configuration.
For example:
ORACLE# configure terminal ORACLE(configure)# media-manager ORACLE(media-manager)# realm-config ORACLE(realm-config)# additional-prefixes 192.168.200.0/24,192.168.201.68 ORACLE(realm-config)# done realm-config identifier early-media addr-prefix 0.0.0.0 network-interfaces media2:0 mm-in-realm disabled mm-in-network enabled msm-release disabled qos-enable disabled max-bandwidth 0 max-latency 0 max-jitter 0 max-packet-loss 0 observ-window-size 0 parent-realm dns-realm media-policy in-translationid out-translationid in-manipulationid out-manipulationid class-profile average-rate-limit 0 access-control-trust-level none invalid-signal-threshold 0 maximum-signal-threshold 0 untrusted-signal-threshold 0 deny-period 30 symmetric-latching disabled pai-strip disabled trunk-context early-media-allow reverse additional-prefixes 192.168.200.0/24 192.168.201.69 last-modified-date 2006-05-11 06:47:31
