Configuring the SIP Interface
To configure a SIP interface:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the system-level configuration elements.
ORACLE(configure)# session-router
Type
sip-interface and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# sip-interface ORACLE(sip-interface)#
From this point, you can configure SIP interface parameters. To view all sip-interface parameters, enter a ? at the system prompt.
- If configuring an existing interface, enter the select command to select the interface.
options—Enter early-media-sdp-realms as the option. If adding to an existing list of options, use a preceding plus (+) sign.
options +early-media-sdp-realms
Continue to the next section to configure the outbound realm.
For example:
ORACLE(session-router)# sip-interface ORACLE(sip-interface)# options + early-media-sdp-realms ORACLE(sip-interface)# done sip-interface state enabled realm-id access1 sip-port address 192.168.1.30 port 5060 transport-protocol UDP allow-anonymous all carriers proxy-mode Proxy redirect-action contact-mode maddr nat-traversal none nat-interval 30 registration-caching disabled min-reg-expire 300 registration-interval 3600 route-to-registrar disabled teluri-scheme disabled uri-fqdn-domain options early-media-sdp-realms trust-mode all last-modified-date 2006-05-10 18:27:31
