max-priority-bandwidthEnter the amount of bandwidth you want to want to use for priority (emergency) calls. The system first checks the
max-bandwidth parameter, and allows the call if the value you set for priority calls is sufficient. If there is not enough priority and non-priority bandwidth allotted for an incoming call, the
Oracle® Enterprise Session Border Controller rejects it.
This parameter defaults to 0. You can enter any value between 0 and 999999999.
