Accounting REPLY Packet
The TACACS+ daemon sends an accounting REPLY packet to the Oracle® Enterprise Session Border Controller to report accounting results.
The accounting REPLY packet format is as follows.
+-----------------------------------+ | Common Header | | | | type contains 0x3 | +-----------------+--------+--------+ | server_msg_len | data_len | |--------+--------+-----------------+ | status | server_msg ... | +--------+--------------------------+ | data ... | +-----------------------------------+
server_msg_len
This 16-bit field contains the length, in octets, of the server_msg field.
data_len
This 16-bit field contains the length, in octets, of the data field.
status
This 8-bit field contains the status of the previous accounting request. Supported values are:
0x1 — Success
0x2 — Error/Failure
server_msg
This optional variable length field can contain a message intended for display to the user. This field is unused in the current TACACS+ implementation.
data
This optional variable length field can contain miscellaneous data. This field is unused in the current TACACS+ implementation.
