Accounting Scenario
The Oracle® Enterprise Session Border Controller initiates the accounting session with an accounting REQUEST START.
+-----------------------------------+ | Common Header | | | | type contains 0x3 | +--------+--------+--------+--------+ | flags |authen_ |priv_lvl|authen- | | |method | |type | | 0x02 | 0x05 | 0x00 | 0x01 | |--------+--------+--------+--------+ |authen_ |user_len|port_len|rem_addr| |service | | |_len | | 0X01 | N | N | N | +----+---+--------+--------+--------+ |arg_cnt |arg1_len|arg2_len|arg3_len| | 3 | N | N | N | +--------+--------+--------+--------+ | user | | login name of an admin user | +-----------------------------------+ | port | | tty10 | +-----------------------------------+ | rem_addr | | localhost address | +-----------------------------------+ | AVP | | task-id=13578642 | +-----------------------------------+ | AVP | | start_time=1286790650 | +-----------------------------------+ | AVP | | service=shell | +-----------------------------------+
- The flags field contains an enumerated value ( 0x02 ) that identifies an accounting REQUEST START.
- The authen_method field specifies the method used to authenticate the ACCOUNTING subject — 0x05 for TAC_PLUS_AUTHEN_METHOD_LOCAL (authentication by the client).
- The priv_lvl field specifies the privilege level requested by the user — 0x00 for TAC_PLUS_PRIV_LVL_MIN.
- The authen_type field specifies the authentication methodology — 0x01 for TAC_PLUS_AUTHEN_TYPE_ASCII (simple login).
- The authen_ service field specifies the requesting service — 0x01 for TAC_PLUS_AUTHEN_SVC_LOGIN (login service).
- The user_len field contains the length, in octets, of the user field.
- The port_len field contains the length, in octets, of the port field.
- The rem_addr_len field contains the length, in octets, of the rem_addr field.
- The arg_cnt field contains the number of arguments in the message body.
- The arg1_len field contains the length, in octets, of the task_id AVP.
- The arg2_len field contains the length, in octets, of the start_time AVP.
- The arg3_len field contains the length, in octets, of the service AVP.
- The user field contains the login name of an admin user.
- The port field contains the name of the Oracle® Enterprise Session Border Controller port on which authentication is taking place. Following Cisco Systems convention, this field contains the string tty10 .
- The rem_addr field specifies the location of the user to be authenticated. This field contains the localhost address.
- The arg1 field contains the mandatory task_id AVP.
- The arg2 field contains the mandatory start_time AVP.
- The arg3 field contains the mandatory service AVP.
The TACACS+ daemon returns an accounting REPLY reporting the status, indicating that accounting has started.
+-----------------------------------+ | Common Header | | | | type contains 0x3 | +-----------------+-----------------+ | server_msg_len | data_len | | 0 | 0 | |--------+--------+-----------------+ | status | | 0x01 | +--------+
- The server_msg_len and data_len fields both contain a value of 0 , as required by the TACACS+ protocol.
- The status field specifies the authorization status — 0x01 for TAC_PLUS_ACCT_STATUS_SUCCESS (accounting processed).
The Oracle® Enterprise Session Border Controller reports ACLI command execution with an accounting REQUEST WATCHDOG.
+-----------------------------------+ | Common Header | | | | type contains 0x3 | +--------+--------+--------+--------+ | flags |authen_ |priv_lvl|authen- | | |method | |type | | 0x08 | 0x05 | 0x00 | 0x01 | |--------+--------+--------+--------+ |authen_ |user_len|port_len|rem_addr| |service | | |_len | | 0X01 | N | N | N | +----+---+--------+--------+--------+ |arg_cnt |arg1_len|arg2_len|arg3_len| | 4 | N | N | N | +--------+--------+--------+--------+ |arg4_len| user | | | login name of admin user | +--------+--------------------------+ | port | | tty10 | +-----------------------------------+ | rem_addr | | localhost address | +-----------------------------------+ | AVP | | task-id=13578642 | +-----------------------------------+ | AVP | | start_time=1286790650 | +-----------------------------------+ | AVP | | service=shell | +-----------------------------------+ | AVP | | cmd=configure terminal security | +-----------------------------------+
- The flags field contains an enumerated value ( 0x08 ) that identifies an accounting REQUEST WATCHDOG.
- The arg4_len field contains the length, in octets, of the cmd AVP.
- The arg4 field contains the mandatory cmd AVP.
The TACACS+ daemon returns an accounting REPLY reporting the status, indicating that the ACLI operation has been processed.
The Oracle® Enterprise Session Border Controller reports an admin user logout or timeout with an accounting REQUEST STOP.
+-----------------------------------+ | Common Header | | | | type contains 0x3 | +--------+--------+--------+--------+ | flags |authen_ |priv_lvl|authen- | | |method | |type | | 0x04 | 0x05 | 0x00 | 0x01 | |--------+--------+--------+--------+ |authen_ |user_len|port_len|rem_addr| |service | | |_len | | 0X01 | N | N | N | +----+---+--------+--------+--------+ |arg_cnt |arg1_len|arg2_len|arg3_len| | 3 | N | N | N | +--------+--------+--------+--------+ | user | | login name of an admin user | +-----------------------------------+ | port | | tty10 | +-----------------------------------+ | rem_addr | | localhost address | +-----------------------------------+ | AVP | | task-id=13578642 | +-----------------------------------+ | AVP | | stop_time=1286790650 | +-----------------------------------+ | AVP | | service=shell | +-----------------------------------+
- The flags field contains an enumerated value ( 0x04 ) that identifies an accounting REQUEST STOP.
The TACACS+ daemon returns an accounting REPLY reporting the status, indicating that accounting has terminated.
