Boot Loader Requirements
Acme Packet 4500 Boot Loaders
The Acme Packet 4500 requires Stage 1, Stage 2, and Stage 3 boot loaders.
Stage 1 and Stage 2 boot loaders should be dated no earlier than July 3, 2013 (MOS patch # 18185632) . Use the show version boot command to view current boot loader version on your system.
Stage 1 and Stage 2 boot loader updates are available on My Oracle Support listed under the respective hardware.
The Stage 3 boot loader accompanies the OCSBC image file, as distributed. It should be installed according to the instructions found in the Installation Guide.
Acme Packet 4600, 6100, and 6300
The Acme Packet 4600, 6100, and 6300 require a Stage 3 bootloader that accompanies the OCSBC image file, as distributed. It should be installed according to the instructions found in the Installation Guide.
