Check /boot for free space
On the
Oracle® Enterprise Session Border Controller, check for adequate space in the
/bootvolume to upload the new boot image and bootloader. Use the check-space-remaining boot command.ORACLE# check-space-remaining boot code: 24759488/25760512 bytes (99%) remaining ORACLE#
You may delete files from an SFTP client if you need to free space.
