Image and Bootloader File Conventions
The Acme Packet 4500, 4600, 6100, and 6300 should be provisioned with the 64-bit Oracle® Enterprise Session Border Controller image file in the boot parameters. 64-bit image files are recognized by the "64" between the image revision and file extension. e.g., nnSCZ730.64.bz .
All platforms require that you install a stage 3 bootloader. The Stage 3 bootloader is identified by ending with a
.boot extension. Stage 3 bootloaders and system image files have identical name portions of the filename, and are distributed together. For this software the GA system image and Stage 3 bootloader are
nnSCZ730.64.bz and
nnSCZ730.boot respectively.
