Update the Stage 3 Boot Loader and System Image
Whenever you upgrade the software image, upload the stage 3 boot loader image file and reboot the system with the new system software image. The stage 3 boot loader is backward compatible as well, so you can still boot into older software images with a newer stage 3 boot loader.
To ensure compatibility, copy the stage 3 boot loader to
/boot/bootloader before you update the boot parameters to use the new software image file. The boot loader file must be renamed to
/boot/bootloader on the target system with no file extension. When upgrading an HA pair, you must perform the upgrade procedure on each HA node.
Procedure
- Obtain the stage 3 boot loader image file (*.boot).
Upload the stage 3 boot loader image file (*.boot) as
/boot/bootloaderto your system using an SSH File Transfer Protocol (SFTP) client. - Upload the new system software image (*.bz) to /boot/.
[Downloads]$ ls -la total 148820 drwxr-xr-x 2 bob src 4096 Jun 17 15:16 . drwxr-xr-x 28 bob src 4096 May 21 14:17 .. -rw-r--r-- 1 bob src 10164527 Jun 17 15:15 nnSCZ720.64.boot -rw-r--r-- 1 bob src 73849839 Jun 17 15:15 nnSCZ720.64.bz [Downloads]$ sftp user@172.30.46.20 user@172.30.46.20's password: Connected to 172.30.46.20. sftp> cd /boot sftp> put nnSCZ720.64.boot Uploading nnSCZ720.64.boot to /boot/nnSCZ720.64.boot nnSCZ720.64.boot 100% 9926KB 9.7MB/s 00:01 sftp> rename nnSCZ720.64.boot bootloader sftp> put nnSCZ720.64.bz Uploading nnSCZ720.64.bz to /boot/nnSCZ720.64.bz nnSCZ720.64.bz 100% 70MB 14.1MB/s 00:05 sftp> bye Received disconnect from 172.30.46.20: 11: Logged out. [Downloads]$
Next Steps
Set the boot parameters to boot the new system software image, and reboot the system.
